So to help me stay organized, here is a list of items brought up as potential culprits. My bike is a non ABS '96...
Pending investigation:
ECM - as suggested by Superzuki in post #56
Fuel Pump Relay - potential heat cracks as outlined by ladder106 on this thread? (
https://www.st-owners.com/forums/showthread.php?127541-ST1100-won-t-start-when-hot/page8)
Coils - crimp connectors affected by heat (suggested by ST1100Y in post #40)
Carbs - Synched at the March 2012 IN Tech Day. Have not torn into them since I purchased the bike with 22,000 miles in 2008 (currently has 53,000 miles on it).
Fuel Pump - No longer running OEM pump. Replaced with the Airtex E8371 in March 2011. Have not tested it's flow rate and if I end up doing so will make sure I don't catch fire like George did.
Not Likely
Vaccuum Bypass Valve - it was bypassed back in 2010 when I was seeing similar symptoms that eventually I diagnosed as the fuel pump seizure syndrome.
Fuel Filter - No longer running OEM. Replaced in 2012 with Purolator Pro 806 that has replaceable cartridges. Although it didn't look like it needed it, I went ahead and replaced the cartridge in early May 2013 before my BBG run to CO.
Air Filter - Replaced in 2012 with EMGO filter.
Spark Plugs - they were pulled and looked at when Gary came up to my place and we found the loose electrical connection to the fuel pump in November 2012. To my recollection, they looked normal and although I had purchased new ones with the intent of replacing them, we put them back in so we didn't introduce another variable to the mix. I would have to pull them again to match their coloration up against the thread you are referencing. I've seen that thread as well somewhere...
Gas Cap & Vent tube - have opened the cap without hearing any rush of air when the bike has died on me, so it doesn't appear to be a venting issue.
