PmodelinUS
Its' April 18th just north of Chicago. Went out looked at my bike looked at the snow said several unkind words about the weather and drove the cage. Maybe tomorrow : (
Two years ago I did the water pump rebuild on my st, it’s a lot of work the front engine cover has to come off, but the real problem was the radiator cap was not letting the pressure off at 16 psi , I had the cap up to 28 lb and it still didn’t release at that point I didn’t want to go any higher.Joe, you what? Oh well, welcome to the world of computers!
After Bill and I spent three days worth of work on the 2004#2, I rode it in today to give a good shake out ride! It did great. Still a whiff of coolant, but it's not on the ground, so...
I'll probably ride it in tomorrow also, and then once Bill gets his permit from Nevada, I'll turn it over to him.![]()
I finally received the socket head bolts and washers that I sourced through Fastenal. Got them mounted up and they look great. FWIW, the right side went on with no fuss. The left side, not so much. I had take a clamp and "pull" the inner frame rearward to line up the holes. Not a big deal once I used the clamp.Finally got my new rear tire put on this morning. Now I'm riding on a pair matched pair of T32s.
I also had the new rear drive cushions and aluminum inserts installed. It sure makes a difference.
And I made sure the mechanic used my Loctite paste, and not the blue Bel-Ray they normally use.
Oops, I didn't mean to quote that post. And MY post is regarding the tip over bars I got from Campbell.I finally received the socket head bolts and washers that I sourced through Fastenal. Got them mounted up and they look great. FWIW, the right side went on with no fuss. The left side, not so much. I had take a clamp and "pull" the inner frame rearward to line up the holes. Not a big deal once I used the clamp.
You need to post a photo of the tyre valve arangement on those wheels; a friend has just bought a 1200RS and they are a really elegant feature.
I just carry 2 spares with me ,, just in case-- One for me and one for a fellow rider in need..Ya never know...Tackled the 3-way plastic T mod.
I just received and put the same pair into my storage unit for the Red Mistress. She won't need them till after Rolling ROCKSTOC, but she'll need them for the fall tour.Picked up a new pair of shoes for Brego![]()
After reading many positive reviews, thought I would give them a try. As like you, they will serve a “later in the season” purpose; I’ll probably install them a few weeks before Rolling ROCKSTOC. With the Tupperware off and the terrible weather, I’m taking care of a few projects that I’ve been wanting to do for a while.just received and put the same pair into my storage unit for the Red Mistress
This will be my 4th pair?... well, and a couple of extra rears in the mix. I guess I like them lol. I used to run the Avon Storms until Avon got political over them fitting the ST1300.After reading many positive reviews, thought I would give them a try.
