Wanted Highway Pegs/ Blades ST1300
Toney, AL
2006 Honda ST1300
I'm looking to see if anyone has highway blades for the ST1300. The $350 PSR wants seems a little steep.
Hopefully a used set will show up for you.
If not, $350 may be a little steep until you use them.
Also for my 34” inseam the PSR blades have been the only worthwhile blades to have. Had MCL blades but legs just felt cramped up in a different position.
Besides the better reach distance for longer legs, they are longer, meaning wider when extended. Legs can splay out past the fairing deflectors if you have them.
I’ve seen where some will have to remove the maintenance access portion of the deflector to work better with the shorter blades.
Thank you. It looks like MCL went out of business which has left PSR as the only ones available. I have a bad knee that starts hurting after an hour or so. You're right though, if nothing turns up I will probably just spend the money.
I have the copies and would sell them. Let me know if interested.
I'd sell my PSRs cheap. Never been used. Only problem is that I don't have the hardware, just the blades. I contacted the company to get the bits but they never replied.
Do you have st1300 peg lowering blocks?
Motorcycle larry type ones?
I have some nice ones, somewhere in the shop. Not sure if they’re the “Larry” type but I’ll see what I have and upload a pic. Based on what I’ve taken off my bike, the previous owner must have been much taller than my 5’11”.
Le
Let me know. I have 2 of those bikes. I'm 6 foot 2 . Thank you sir
