Well, the 1st one lasted about a week, and then died. I thought, ok, it happens. I ran through their trouble-shooting guide, checking all voltages under the given combinations and everything checked out fine. I checked the little red LED inside the servo unit, and it would illuminate whenever I pressed either "set" button on the control panel or pressed the brake. I even connected my engine diagnostic meter to the coil lead to ensure that the unit was receiving a signal, and it was. I then popped the vacuum line off of the reservoir and it had oodles of vacuum built up. I stuck my vacuum gauge on the hose and it showed 10psi at idle and climbed to over 13psi at 4000 rpms.
So I purchased another with plans to send the first one back for repair and then sell it. I installed the second one, including the button panel, and this one has failed to function at all. I've performed all of the same checks as I did with the first, and everything checks out fine.
Ok Obi-Wan, what now?
