I haven't got a clue - but I can read a circuit diagram.
My best guess is that the right sensor (Red/Blue wire) connects to pin 9 - top row, 9 pins from the left.
The Left sensor (blue wire) connects on pin 22 - immediately underneath pin 9.
But you should never rely on information from just once source - so here is my exaplanation as to why I come to this conclusion so that you can check it for yourself.
I have the printed Honda Service manual for UK ST100 A2 to A4. It contains the circuit digram for Spanish bikes as well as UK. This information is gleaned from that.
I checked it with USA circuit diagrams and they seem to be different.
The 2003 Spain diagram for the luxury (ABS) version shows the
BL wire going into pin 22 of the Grey connector.
The R/Bu wire going into pin 9
The fuel system testing part of the manual for FI error codes 25 and 26 indicate
that the Right knock sensor is the red/blue wire
the left knock senosr is the blue wire.
So I guess that someone made a mistake in the circuit diagram and labelled the Blue wire as 'Bl' when it should be 'Bu'
But there is no doubt that the wire labelled Bl comes from the knock sensor (Except the circuit diagram doesn't lable the side of the knock sensor.
The text of the testing section in the manual shows the 26 pin connectors and labels them from left to right - top row pins 1 to 13, bottom row pins 14 to 26
So Pin 9 is directly above pin 22.
There is the opportunity for these pins to be looked at upside down or from the point of view of the mating connector. So to be sure, there are two vertical mouldings between the top row and the bottom row so that they cannot be plugged together the wrong way round.
One moulding is on the left between pins 1/2 and 14/15
the other is roughly central between pins 6/7 and 19/20
You can see these in the poor quality images that I pinched from an on-line manual. My printed one which shows the same diagrams is much clearer.
So pins 9 and 22 are the thrid pins to the right of the central moulding.
But there are rumours around that the manual has the fault codes 25 and 26 the wrong way round anyway. So I guess it doesn't matter which is left and which is right !!
The diagram below is from the manual to show the test harness. I have made a big assumption that the grey connector is the one that I have labelled - because elsewhere I read that the knock sensor pins are in the grey connector and that connector is shown on the right in the circuit diagram.
I repeat - I do not know any of this - I have the 2003 UK and Europe manual so I have tried to work out what goes where from that. The circuit diagram for Spain is the same as the diagram for UK as far as the knock sensors and the ECMs are concerned - but they appear to be different from the circuit diagrams that are published on this site.
This is all that I can find - check it through to see if it makes sense according to the wiring that you have in your hand. If any of it doesn't match, then everything that I have written is probably incorrect.
