Mirror Housing Tether
Victoria BC, Canada
2004 ST1300
Part 13 in the fiche.
The big tie straps/zip ties.
My bike came with these attached at the housing end with a screw, but not attached to anything at the other end.
I can’t see where, or to what they attach to.
Is there something that has disappeared behind the fairing framework where the turn signal wires go?
Stumped.
Stumped.
I haven’t had an ST1300 for a while but my recollection is the loose end is sort of keyed so when turned just right fits in a hole in the fairing but won’t come back out unless it’s turned just right in order to be pulled back out.
Mine came with it zip-tied around the little strip where the wires come out. I thought that's how it was supposed to be until Igofar showed me otherwise, Now I just slip the large end of a zip tie into the slot.
This. One of mine was loose but the other was attached. I haven't looked but I think the keyed hole was in the metal subframe and not the fairing itself.
I found that it narrow end - where the zip tie was screwed into the housing - was a weak point, and would break off over a short period of time. So I discarded that original arrangement.
Instead I have a strong zip tie looped through the hollow pivot of the mirror mount, zipped to itself on the outside.
Another strong Zip tie loop threaded behind one of the three mounting posts for the indicator light. You have to slacken the screw to thread it behind the post. Again, zipped loosely to form a loop.
The original releasable Zip tie is used to link those two lops to prevent the mirror housing hitting the ground..
Someone once pointed out that this method introduced three potential points of failure, rather than just one. But it has never failed on me. The original method - the zip tie cracked every time near the screw on the mirror housing. (Four mirrors, two bikes. The first few times, I cut off the cracked end and drilled a new hole. to effect a repair, but it soon cracked again. The problem is that the load is at right angles to the screw head, and I have a standard Uk garage - wide enough to fit a car, but barely wide enough to open the door to get out. So the car has never been in the garage. But squeezing past the motorbike often results in the mirror housing being knocked off. It gets a lot of testing!
It's also a good idea to stick a 2" long bit of Insulation tape underneath the mirror housings - along the seam where it meets the fairing.
[Try it John, it should stop that problem when squeezing past. ;-)]
It's an idea the I tried - with broad transparent tape. But I think I'd rather that they just knocked off. They are easy enough to put on again. All 6 of my retaining clips have the spring circlips which helps, and having mastered the art of putting them back on without bending the clips, It's not a big issue.
And I ask myself if they're not even supposed to detach under force, before causing any further damage to other (even more expensive) fairing parts... :unsure:
I use a smaller zip tie through the mirror zip tie and then thread the smaller one through the upper fairing openings, where the mirror housing attaches.
In 400,000 miles, the only ones I lost were when I was hit in 2008 & 2019. And they were all busted up anyway and needed replacement.
