Reverse bleed method?
Apex, NC
GL1800 & ST1300
Has anybody used the reverse bleed method, where you pump fluid from the caliper up to the reservoir with a 100cc syringe?
Will this method work on the ST1300 with the linked brake system ?
The better solution is a pressure bleeder. You can get adapters that will replace the brake/clutch reservoir plates, and it pressurizes the system so you can just open the bleeder with it under pressure to flush. The one I use has a tank that replenishes what is pushed out so you don't run low.
I use it for my cars as well. Saves a ton of time.
Except those really push crap around in the system, and I have see. The
Clog up the cartridge in the SMC when used.
