Last spring I was losing coolant monthly. As part of the troubleshooting, I took off the radiator and tightened all hose clamps near the thermostat: they were loose and there was evidence of leakage. I figured that this solved my coolant leakage problem.
Flash forward to today: I just did the 60k maintenance on my 2003 ST1300A. The reserve coolant tank was at the low level - I had filled it at the 56k maintenance interval. Over the last few months I've occasionally smelled coolant at stoplights, particularly when the fans come on. I've attached pictures of the front of the engine casing.
My questions:
1. Should I retighten the hose clamps?
2. What about replacing all hose clamps with aftermarket items?
2. Do I need to replace the water pump mechanical seal?
3. If #2 is true, do I really need the special equipment listed in the service manual?
My questions:
