endy53
Your water pump has two seals in it. A Slipper seal for the coolant and an Oil Seal that seperated the chain drive of the impeller from the water pump side. If these seals start to go bad then they will leak from the weep hole. See pictures
Hi, I know this is an old thread, but I'm just about ready to undertake the seal replacement given the "weep hole" leak on my 04. Quick question though, and possible more to follow after I start the task!
Apart from the impeller, do all of the seals, including the one nearest impeller get pressed in from the engine side of the casing? Its just that all of the pictures I have viewed, I find it difficult to work out in relation to the impeller does that bearing /seal orientate.
Many thanks.
