Lost to the ether. If you recall, it involved a dial indicator and home-made shim.
I recall the fix but not how to come up with the numbers. You sure it's lost? I know I've seen the pics somewhere.
And it is true, all motorcycles are off to some degree. The swingarms I've checked vary wildly including only one that I would deem acceptable. This is why some wobble and some do not. The wheel alignment is one variable in the equation.
If you have a problem it's worth a shot.
George, give the front tire technique a try first.. you never know, it might be enough to correct the issue and worth it if it does.
(BTW, the 1100 manual has no "steps" for reinstall, just "installation is reverse order." I've always pumped up the brakes and tightened the left side clamp bolts last.)
Is there a "trick" that someone knows to solve this?
Yes... since you tried the special set-up and it didn't work. Just put all your heavy gear in the Left bag!
look closely at your front tire you will see the left side is worn more then the right?
I always thought the higher wear on the left side was due to the fact we ride on the right side and most roads are crowned from the center( rain run-off)....your always correcting slightly for the road surface
BTW, I load all my heavy gear in the left bag!![]()
