jfheath
John Heath
Front Wheel Bearing Removal
Note the 'official' Honda tools - but other methods work just as well.
Small taps work best for me. Larger ones knock the tool straight out of the bearing.
Front Wheel Bearing Installation
Note that for the second bearing at least, a flat, solid driver has to be used. The one I am using is the attachment which normally has a handle and a 'pilot' to fit inside the bearing. These hadn't arrived in time, so I just used the attachment. The 3 parts are shown in the photo below - left to right: pilot, driver attachment, driver handle. Alternative tools that do the same job are available, but not easy to obtain in the sizes required for these bearings.
Note that for the front wheel of the ST1300, the right hand bearing must be driven in first to meet the shoulder in the hub. (For the rear wheel, the left is inserted first).
Yes, it matters. Put them in in the wrong order, and the wheels will be slightly displaced on their axles, which may affect brake disc clearance, fork alignment and handling.
But don't take my word for it. Check your workshop manual.
The spacer is fitted, then the left bearing is driven in to meet the spacer. There is a shoulder inside the hub, but the bearing meets the distance collar first, which is why it is essential to have a driver which drives in the inner and outer race simultaneously. Note the checking, so that I can tell how close the bearing inner shell is to the distance collar. As soon as it meets, stop driving.
Other related articles:
ST1300 - Fitting Wheel Bearings - What the manuals don't tell.
ST1300 - Front & Rear Wheel Install and Front Axle Animation
Updated 9 April 2020
