I agree will everyone--great idea. However, my problem is with my heavy duty DeWalt 1/2" drill. The inspection panel area gap is way too small for my drill. I cannot seem to get a straight-inline shot in the deflector that's attached to the body. The dowel will end up kicking out in one direction or the other; to the top, the bottom or out, even if I drill the hole near the outside point of the "v", I stall can't get a straight shot as the hole would still point the dowel outward. And to hell if I'm going pull-off the deflector from the body and re-tape it afterwards--No.Way. So does everyone here have Fischer Price baby-sized drills?
When drilling both holes for the dowel, would trying to match the angle of the hole coming from the body-deflector into the inspector-panel-deflector piece, be worth the calculation? Does it matter what angle the dowel is at as long as it is connecting the two deflector segments? Did anyone else run into this issue at all? Am I nuts and over thinking this? don't answer that one.
:nuts1:
I just drilled my inspection cover first with my cordless 3/8 drill in the middle of the "V" and then placed it back towards the deflector and drilled the other side. Just try to keep the drill as straight possible and you should not have any problems. And no you are not nuts!!
