I may try producing another batch.
I'm sure a lot of riders would appreciate that.
That would be great Rick, you may want to post something in the group buy section w/poll as it may help you estimate the current interest/volume.Note that I have stopped production of replacement gears due to costs, but many all over the world are still requesting these parts.
I may try producing another batch. but would like some feedback from STriders that have used my drive gears.
Please reply carlermotorcycleparts@gmail.com for comments.
warofman9 (Ricke)
Carlermotorcycleparts
I have GEARS! I have sent paypal requests to those on the list......and posted the second document.
Long may you run!
ricke (warofman9)
That red "tab" looks like a retainer. I would try and pull that out and I would think the connector would come off.
I broke some of the black plastic push in screws while taking front cowling and windshield apart. Went to Canadian Tire and they are $4.49 for two. I can buy 100 of similar looking ones on eBay for less than $10. What are they called, what size are they, diameter and length? They are the push in screws that spread apart link a gyproc wall anchor.where can i purchase rhem on line
In this thread https://www.st-owners.com/forums/showthread.php?93564-Windscreen-Alignment-(slipped-a-gear)/page3 , it shows a picture of what looks like you have and it looks like there is a tab off the one side that you should push to release the plug from the motor housing.
It also shows a plug at the end of the harness, but if you say that you cant disconnect any other way, then perhaps they hard-wired yours.
I bought one out of the first batch, but it turned out to be a bad cable, so the gear is still sitting in my parts bin.4:
just thinking that if your problem was just the cable..... did your screen tilt to one side while still working. I raised my screen up on one side on the manual adjustment and stopped using the power up and down for fear of damaging cables beyond repair. I still haven't taken cowling off to inspect the damage. My question again is , What was actually wrong with the cable on your bike if it wasnt a stripped drive gear ? I too may not need to purchase drive gears before I dismantle it but would obviously be a bummer if I stripped it down to find a stripped gear and not hasving at least 1 replacement . Ive written to Riche to see if he has any replacements but thinking from his latest posts that there may not be any. Could you get back to me with any ideas please. Be appreciatedHi. do you still have that windshield drive gear of riche's. if so would you be interested in selling it ? desperate owner of broken windshield mechanism
hey Vincent. that looks like an interesting and very cheap fix. I havent dismantled my ST windscreen mecanism yet so its all theory to me so far. it appears that windscreen failure isnt always the same problem. slide bits can pull off cables. hopefully mines not a stripped gear but others have got around that too it seems. did your screen tilt to one side when it failed ? Im still getting around to attempting this repair but its good to hear about different scenarios as the problem varies. Im starting to think my problem may only be a bit missing off a cable.
