Great post, got a laugh of your description. I have had all of those moments.Thank you so much for this.
I stumbled around reading endless text on how to do this...all of it reducing me to a cursing lunatic.
What fuggin tabs on the clips on the plug before turning the wire to the left if you're right handed and push if you not while lifting on the snoozle flugin with you index thumb and be sure to angle the tangle before pulling the tucksit and bending the jiggamthing?
A picture is worth a thousand words. A video is worth ten thousand.
I changed the left years ago. Now it's the right side's turn. This video makes it a 2 minute job as opposed to the previous one that was at least 30 minutes and 2 wrenches through the wall with taunts of damnation for every automotive and motorcycle design engineer who doesn't work on their own machines or have hands the size of Achmed the Dead Terrorist.
Simple, clear, great video. Thanx again.
Thanks for your video. Can you provide advice or recommendations on going LED. Would to hear everyone's opinion.I put this video together while I had my bike torn apart. You have to do it blind and by feel, so this is nice to see what you’re actually doing. It’s an easy task once you know what you’re doing, but until then, it can be a struggle! Even the experienced bulb changers may appreciate this!
Ooops...sorry ad.hom. It's been a number of years since I've been on the site.
Excellent! Thanks!I put this video together while I had my bike torn apart. You have to do it blind and by feel, so this is nice to see what you’re actually doing. It’s an easy task once you know what you’re doing, but until then, it can be a struggle! Even the experienced bulb changers may appreciate this!
Thanks, I’ll give it a look.Rovidan check out this thread about the headlight circuit, https://www.st-owners.com/forums/threads/st1300-headlight-circuit.175199/#post-2273041. You will need to get in there with a test light or a volt meter to see what is what.
Just replaced the Left headlight, following advice shown in the video. But I wonder if I installed things correctly:
The bail clip didn't feel like it hooked in as far as I thought it should, but it seems to look like what was in the video.
The rubber collar snapped in just fine, but I wonder if the interior seal looks correct.
Would appreciate another set of eyes.
Thanks for any help.
Good to know. Thanks.I don’t suppose it matters but there is a TOP marked on the rubber seals. The tabs end up being at 12 and 6 o’clock.
Either your headlamp had the original configuration bulbs in it, or they were not properly installed if they were automotive H4/9003 bulbs. If the latter is the case, the beam pattern must have been screwed up as well.Even though I own the same year as the OP, my bulb came out with tabs extended, so I didn't bend them on the new bulb. Not quite clear on the relevance, just wonderin'.
Because of the design of both the ST1100 and ST1300 headlamp assemblies, lighting regulations in North America limit their maximum allowable bulb wattage to 45 watts. This results in underwhelming light output.The failed bulb is the original and I replaced it with oem.
