After I washed it, that's when I got that much coolant coming out, I've been smelling a coolant leak for about 3 weeks, but VERY slight, and only about an inch down on overflow tank. My driveway is sloped and when I washed it (with plastic off) I know I got a lot of water in the V, when I rolled it in the garage (level) is when it all ran out. Just dreading the job of digging into the V area, but I'm pretty sure now it's in there someplaceNothing wrong with your water pump, what your seeing is leakage from the t-stat housing and water pipe hoses.
It exits into the front cover, then follows the seam down and exits the square area where the cover meets the engine.
Unless you’ve been neglecting the service stuff, with that much coolant on the bottom and lower cowl, you may have a damaged hose or pin hole in your radiator from a rock strike.
You could always ride it over one state and I could take it hostage and fix several things for ya.
Thanks for the offer and adviceCoolant leaks look worse than they are on these bikes but it doesn't take much to fix the simple problem of weeping hose connections that drain down the front of the engine and exit the square drain hole. You are already familiar with removing the fairing and that is a good amount of the time required. With the fairing off and the radiator removed it's simple to access the radiator hoses and the other cooling system hose connections at the thermostat and cylinder heads. With a long screw driver and a 6 mm socket on a couple of extensions you snug up the hose clamps. Simply snug, not over tighten. While it is accessible it's good to go ahead and replace the O-ring sealing the thermostat housing. The part number for the O-ring is 91361-MCS-A10. I have a pdf tutorial that shows how to remove the radiator to access the thermostat housing. Replacing the thermostat may not be called for if the bike warms up normally and shows three bars on the coolant gauge while being ridden but the steps to drain the coolant and remove the radiator are necessary to access the V from the front. If you want a copy of the tutorial PM me your email address.
That's easy- time to ride!Don't know what to say about that
You could say you left 7 loose clamps in thereAs impossible as it seems, the one hose clamp I could get to, looks to be the one that was leaking. Tightened 1 clamp, and the coolant smell is gone
Yeah, trust me I'm thinking about that. Went in from the front, not sure I'm up to going in from the top, intimidated by pulling the throttle bodiesYou could say you left 7 loose clamps in there![]()
That's what I'm hoping for LarryBe careful what you wish for.
Your liable to find out just how much your bike can be improved upon.
