Article [13] ST1300 - Under mirror light mounts - easy DIY and under $5.00
Obo
East Coast Canada
24 GL1800 Tour DCT A
I've been wanting to add a small set of LED lights under my mirrors, but didn't want to spend the $100US for a set of the 3d printed ones.
I've been looking at other options and today I found an easy and simple solution, most of it already installed on the motorcycle.
With the mirror covers removed I took a look at the mirror housings. They are bolted to the fairing securely. The rest of the mirror housing sits over top of an upright hollow shaft and is held in place by a locking spring. It effectively is a hook the rest of the mirror sits in.
Here you can see the top and bottom views, the hollow shaft and the locking ring.
The hole in the mount is just under 1/4" at the top and just over 1/4" at the bottom. I got out my drill and drilled the top out to 1/4". You're really only shaving out the smallest amount of material on just the top lip. The fit is tight enough you'll have to thread the carriage bolt down in, which is the next step
I then got two carriage bolts 1/4" x 5" a couple of washers and 6 nuts. (edit: if you want more hanging room buy the 6" bolts and trim them if required.)
I fed the bolts down through the top of the mirror mounts. I had to thread them down by hand. You don't want to force them or beat on them. They will go with some easy turning. I had one that got tough at the final threads so I just double nutted the bottom and using a socket turned it down snug (so the square shoulder is resting on the top mirror flange.)
I then put on a washer, lock washer and a nut and spun them up to the bottom of the mirror, tightening them to secure the bolt thru the hollow mirror mount tube.
I installed one of the lights I already had on hand using two more nuts and washers. (one on the top and one on the bottom of the light bracket) for a test fitting.
The plastic mirror cover was held up and marked where the bolt came down (just behind the bottom snap in pin) and I trimmed it with an oscillating tool so the bolt would pass thru.
Here's what it looks like with the cover on.
I think they turned out very nice.
Costs were $1.25 for each bolt and 0.17 for each nut. I went with galvanized as the hardware store didn't have stainless in 5" length. I already had some washers and lock washers at home.
The lights seem secure and I nudged them up against the Tupperware with hopes there would be no vibration when driving.
I've not yet had them on the road as I still need to wire them up.
The only thing I'll add is this may not work for all lights. If they are wide they may not clear the Tupperware. I'd imagine they'd hold more weight than the 3d printed versions of the mounts though.
Hope this helps someone!
edit: I added a bit of black heat shrink tubing over the bolt to cover up the bit of bolt showing under the light. You don't want to shrink it, just let it cover the bolt. That way you can easily remove it if you have to remove the bolt to take the Tupperware off.
I picked up the lights at Princess Auto when they were on sale. They are currently on sale for $30.03 for a pair.
The brand is Trux and the model are TLED-U105. They are indeed LED and have a spot and flood emitter. They both light at the same time. There is no option to choose one or the other.
I can't speak to how well they are as I've not used them except to see how they looked in the yard attached to a battery. My son did use a set on a quad racer as it's headlights.
You could dress that bolt up a bit with some SS tubing or something that could be sanded and painted. Then cut it to length to fit over the bolt and you have an even tidier installation.
Those are some big lights if the site's specs are accurate — 7.5" x. 5.875". Those specs are also pretty close to the dimensions claimed for the box.
Funny I'd never seen that thread. Thanks for sharing. Great minds do think alike.
I first saw a similar set up on playinatwork's (Tim) 2006 ST1300. I wasn't the first to use the hollow mirror mounts to hang a set of lights but it does work very well for very little.
  • Like
Reactions: Obo
Nope, they are 3" x 1.89" x 2.25""
I didn't dress the bolt as it has to thread though the mirror, and has to be easy to remove if you want to take the Tupperware off.
So much for the site’s specs. Maybe they misplaced the box dimensions.
I was refer to the exposed area between the nuts at the bottom of the mirror mount and the nuts at the top of the light mount after installation.
That could be painted in place (with some masking) or some tubing slid onto the bolt before mounting the lamp. Just a thought.
  • Like
Reactions: Obo
I threw the relay for the new lights under the passenger side fairing with the horn, fork light & headlight flasher relays I just added and for control used a small latching switch on the handlebars next to my heated grip controller to manually turn them on or off. As the bars are slightly rounded and the back of the switch flat I used some Alien tape to secure it.
(Having the hand gear off a PA with the extra switches would sure be nice!)
I may wire the lights into the horn headlight flasher circuit in the future.
Here's what they look like on with low beams (yellow driving lights)
and with the high beams (white driving lights)
