What did you do with your ST1100/ST1300 today?
Can't say it was today, but put my babies in storage for a while. For reference, this is a 10' wide by 7' deep.
I found the battery dead again on a recently purchased 1100. When the battery tender showed it wouldn't charge it, I brought the real charger over. Took the side panel off and saw why it wouldn't charge it. The 4 wires hooked to the positive terminal drained it flat dead. Messed with it a while then swapped out another ST battery. While the tender was topping off the charge, I rewired the accessories. I ran a key switched power line to the 4 wires. Installed the battery and went for a ride. All was good. I'll check it in a week or so to see if it's still holding the charge. I ordered another battery.
@Catmandu2 your pressure trick worked well. (post 3321)
Yesterday after work with just 4 hours the peddle play was much less.
This morning it was much better, and I really noticed the hand brake had improved too.
Even after an hour on the freeway when I hit the city streets it was still good.
I'll have to add this to my tune up list. I used a 15 lb. dumbbell on the foot peddle.
Thanks!
Installed the correct battery, had the bike a few days and noticed the bike didn’t crank over as fast as I thought it should. The PO had the wrong size, way too small, half the CCA as what supposed to be.
Took a little ride up to the Indianapolis Motor Speedway museum. Hadn't been in awhile. It was a great morning for a ride.
Got a few more things added, Wolfman tank bag (5th bike since 2002), new GPS, tire pressure sensor monitors, Ram Mount tray for the heat controller, Seat bead strap. Next will be adding a aux fuse box for heated gear, GPS and battery charger.
Hello,
Installed a aux fuse box this afternoon, needed for GPS, heated gear, aux outlet, GIpro, battery charger connector. Fits next to the ECM, Velcro in place. Still need to add a few wire circuits.
Well tried to go down to Cali today but hundred miles south the rear valve stem gave out and went flat 70 mph. It’s buggered up so will have to have it towed home. At least my tow coverage is premier and up to 200 miles - will have to post pone a day. IMG_4947.jpeg
Sorry to hear JohnK hope the rest of the trip goes well. I had to put a battery in my '06 today. I ride the bike pretty regularly and keep it on the tender most of the time so I'm disappointed with the $200 Yuasa I put in May of 2021. Wouldn't hold a charge for more than a day or so; would get down to 12.1v and wouldn't crank. Charging system seems fine; approx 14.3v at idle. I went with an Interstate AGM this time we'll see.
Did a forty mile or so, around the county ride and then stopped off at the local Food Lion for some Vanilla Bean Ice Cream for the wife. I should have mounted the camera but... I did not.
Finished another major service finally, everything but valves and coolant. Added new rubber and rear shock upgrade from Racetech. Work got in the way this week or I'd be doing a ride report instead.
Just some switch failures to switch out...and then put her clothes back on. The red tail one in the middle is new and waterproof, the others were not.
Some random picts, because we all love them.
A darksider I see…
Hello darknes my old friend . Today I took a ride to the furthest point west on mainland Norway. Got to test my newly mounted Rigid extra lights in dark, old , unlit tunnels on the way. They do the job. There on police brackets.
