Diaphragm/Piston - should it look like this?
The Netherlands
ST1100S
I was wondering if the Diaphragm/Piston looks like this (see picture)?
I can't imagine that it works correctly while it has grown over time....
Can this be caused by using ethanol rich fuel? And ... more important: should I replace them?
Thanks!
Looks indeed like their slightly swollen due that darn ethanol additive... (confirms my aversion against E10 and preference for premium E5 fuel...)
As long as they're not torn or show punctures I'd leave them alone and only see of the sliders move easily...
And I'm with @Uncle Phil, swollen diaphragms will be a real PITA to put back together again...
ST carbs rarely need a full rebuild; pop the float bowls off, clean/replace idle and main jets as well as the float needles & seats (which I clean them with a Q-tip and little Autosol Chrome polish), see if the floats move easily, if the carb needles are corroded, worn or bend (likely not) and install new bowl gaskets when putting all back together...
Even the air cut-off valves are rarely damaged/in need of replacement...
New carb boots (isolators) are kinda mandatory, as they grow hard and kinda "vulcanize" themself on the stubs due the heat... I do them every 2~3 years to maintain an easy removal of the carb assy...
The diaphragm is indeed misshapen, but hardly surprising if its been laid up for a long while with stale fuel and ethanol vapours doing their worst. Plus it's down to age and miles too. There's a danger they will be quite likely to split if messed with too much, but it wouldn't hurt to check they're no worse than that.
Upt.
Why do you have the carbs out? Was the bike running poor or perhaps the water hoses needed replacing? If there are no tears in the Diaphragms they might be OK.
Bike doesn't start and was in the garage for a couple of years now. Only fuel used since the owner has this bike was 95/e10. This fuel is not the best for older bikes I understand. So, I persuaded the owner to use only 98/E5 as that is the only available alternative over here in The Netherlands.
Again, start at the business-end of the carbs: the jets hiding behind float bowls... that E10 crap is prone to leave debris and corrosion there...
Then the fuel supply... does the pump even run and deliver?
Next is ignition system... got spark?
Maybe the kill-switch is corroded (early models will actually crank with this in OFF)...
possible the connector shells behind the head-stock suffered corrosion...
possible the feed on the coils have bad contacts...
possible the ignition lock switch-plate has issues...
possible the starter relay (behind LH side panel, forward of battery) has a melted connector (unplug the red socket to inspect)...
Your diaphragm looks normal like mine.
I remove my carbs few mths ago to chase an issue with high fuel consumption and too rich condition after a shop major service(timing belt, water pump, idler bearings, all water hoses and elbows,carb boots) and clean up the pilot/main jets without splitting the x4 carbs.
Clean and check the diaphragms was not torn and all nooks and crevices that I can reach. Only took out the aircut valve that I can reach and they looked good.
Like Martin mentioned, most carb parts should be good, maybe only the carb bowl gaskets might be a concern, I reuse mine without any problems.
Your diaphragm's are stretched out badly. If you could find inexpensive replacements, I'd replace them.
As it is now, I can possibly see a delay in throttle response in the midrange, or potentially not being able to obtain full throttle rpm's from being so stretched out, not allowing the slides to be fully raised. Under load, you should be able to hit the rev limiter at 8500 rpm's.
Sorry to hijack the thread.
Adam, I’d like to thank you personally from all your in depth posting and replies for the carb setup that helped me resolve my rich running/high fuel consumption that plagued me for over a yr.
Long story short, suspect shop did something to my carbs after service, prior to work mileage was ~15-17kml, after -12-14kml, low gear roll on bogs down with no power, high gear is fine. Mileage very bad during stop and go traffic, highway ride is ok. Range per tank dropped by -50km. Exhaust smells really gas rich, followed your various posts advise to check/setup carbs.
Found the courage to tackle carbs, Pilot screws was found to be adj -2-3/4, clean carbs, setup to -1-7/8(guesstimation for my tropical climate with 40/125 factory jets, no idle drop done) and synch. Bike sounds much better post sync , purrs during lower gears and smooth like butter.
Mostly importantly the mileage is back to normal for my location. Appreciate all your expertise and posts/replies in this forum.
Just a note - if you separate the fours carbs from each other, you will probably lose your mind trying to get them back together correctly. ;)
I've never had that part off a carb so I have no idea.
Well @Uncle Phil I will take it apart as the advice given: one for one. Keep the carbs as a unit and clean it and replace the rubber seals as recommended one carb at a time. Thanks!
Thanks @ST1100Y
Your right about the E10 crap. It not only makes the carb very dirty (on a bike that is only driving a couple of times a year (it has been idle for at least 2 -3 years)) with a tank full of E10 (crap) fuel and also I found out that the fuel pump is not pumping any fuel to the carbs. I also found out the fuel filter was clogged. Hmm. So, I replaced the fuel pump and fuel filter and checked on sparks (replaced all sparkplugs which now all sparks like hell :)). Checked by bypassing the vacuum fuel petcock system and still no running engine. It coughs a couple of times and it looks like she wants to get started, but she doesn't. Removed the carbs and I see that the carbs are not only clogged and dirty but also found the vacuum diaphragm like I shared. Removed the business side of one carb and found that the carb bow gaskets needs replacing. So, I'm ordering the stuff I need and get on with it! Once the carbs are cleaned and I have re-assembled the carbs and put them back on the bike I will update here again!
Thanks @afrymoyer
I will replace them but I think it's hard to find inexpensive replacements.
From what I've seen I think I'll order new ones.
Thanks!!
