ABS light won't go out
Pics of the front wheel please. Showing the sensor wheel, when’s the last time you flushed the brake fluid? Any maintenance performed recently?
My 2007 ST1300ABS apparently is having ABS issues. The light comes on and will not go off.
Any suggestions?
Yes, call me, I have a couple things you will want to test/check before some stealership tries to convince you that you need to replace the very expensive ABS unit (which it never is)
I think it would help to add what older fluid can do to mess up the ABS sensor response. I certainly don't know!
There are several things that won’t throw a code.
Could be something as simple as iron dirt on the magnet, a cracked pulsar ring, wheel spacer put in backwards, bearing dust seal sunk in too far, etc.
Dumb question perhaps but I had an intermittent ABS flashing issue. The sensors were cleaned & the rings looked fine but it progressively became worse to the point where the flashing was constant.
I performed the ABS reset to no avail but on closer inspection for cracks, there appeared to be the slightest rust on the rear ABS rotor between the teeth. I gently used a small brass brush to thoroughly clean the front and rear rotors & went for a ride with multiple engine restarts... SUCCESS! My ABS is back!
My question: is there something I can apply to the ABS rotors to prevent corrosion without compromising function?
Boat supply stores (west marine) have salt-x, corostop, etc.
S100 also makes a spray to stop rust.
