Hey Y’all, 2005 ST1300 - Windshield rises up with no problem, lowering is a different story. Intermittent lowering. Have to press multiple times to lower. Thoughts? Take apart and clean? Just spray with elec contact cleaner? Thank you in advance. Brian…
Seems to be the switch after pushing down with no joyCan you tell for sure it is actually the switch not making contact and not the windshield mechanism that is binding on the way down?
Checking with pushing down on the screen while activating the switch might give an indication.
In other words, it thinks it's already all the way down.the bottom limit switch is dirty or bad. I had this problem also, years ago It does not close to make the circuit for lowering the shield.
Take apart switch? Clean and or replace? Thx, Bthe bottom limit switch is dirty or bad. I had this problem also, years ago It does not close to make the circuit for lowering the shield.
Take apart switch? Clean and or replace? Thx, BIn other words, it thinks it's already all the way down.
Most likely outside the body of the actual switch, such as a lever the switch bumps into.Take apart switch? Clean and or replace? Thx, B
Thank you Sir!Most likely outside the body of the actual switch, such as a lever the switch bumps into.
Look through these: https://www.st-owners.com/forums/search/216314/?q=st1300+windshield+limit+switch&o=date
