1300 bulbs - any direct fit options?
United States
2006 ST1300 - Black
Are there any direct fit (and good...) bulb options for the 1300? I'm not even sure what specifically to search for, since two different style H4 bulbs with different sockets is an absurd concept. I'd greatly prefer LED but I'm open to halogen if they last a while and are decently bright.
As for using automotive style lights, I see some bulbs come with "alignment shims" which don't make much sense to me. Is it as simple as just bending the tabs and inserting it, or will there be alignment issues without these shims that some bulbs specifically marketed for the 1300 are offering?
Sorry for likely beating a dead horse, I've done searches but I'm just not totally sold on the bent tab process keeping the bulb aligned correctly and no threads have really directly addressed this.
Sylvania H4 Silverstar are an upgrade from OEM halogens but do require snipping or bending the lower 2 tabs. This isn’t a big deal. One tab and the bale on the reflector align the bulbs as well as three. The Silverstar Ultra throws more light but they don’t last very long. LEDs are changing so fast it’s hard to keep up with the current best but I use ones without an external cooling fan. Internal fan designs are plug and play with OEM headlight connectors. The last ones I bought were 1:1 Superees on Amazon. 1:1 describes placing the led emitters in the correct relationship to the reflector so the beam placement and cut-off is correct.
No need to invent the wheel with headlight bulbs for the ST1300. No shims are needed.
Sylvania H4 Silverstars are an upgrade from OEM halogens but do require snipping or bending the lower 2 tabs. This isn’t a big deal. One tab and the bale on the reflector align the bulbs as well as three. LEDs are changing so fast it’s hard to keep up with the current best but I use ones without an external cooling fan. Internal fan designs are plug and play with OEM headlight connectors. The last ones I bought were 1:1 Superees on Amazon. 1:1 describes placing the led emitters in the correct relationship to the reflector so the beam placement and cut-off is correct.
Nice, good to know they just pop in fairly intuitively - and without shims.
I must have the stock bulbs in my 06, they are so yellow they might as well be amber. Going to get some LEDs and just overly concerned about orientation, especially since I'll probably buy some nice ones.
The LEDs I’ve used in H4/9003 installations use a two piece bulb with two nibs that engage slots in the base - sort of how an incandescent dual filament tail/brake light bulb engages two nibs to align the emitter in the correct orientation. The base has the tabs aligned in the reflector then the emitter slips through the rubber dust boot from the back.
Yes, LEDs make incandescent bulbs look yellow and dull.
It's been my understanding (and experience) that you have to snip the two lower tabs off an H4 lamp - LED or incandescent - to make it fit an ST. The top tab positions the lamp (in the case of some LED's the tab positions the holder or base).
On the ST1100 if you install automotive H4/9003 bulbs you need to remove the two lower tabs from having any influence on the positioning of the bulb in the headlamp housing in order to be able to properly position them in the headlamp housing. This means that the bulb can now fall in to the headlamp housing because the opening is a tad to large for these bulbs without the two lower tabs. The shims are required to reduce the size of the opening in the headlamp housing to prevent this. This changes the focal point ever so slightly but 99.9% of us will probably never notice the difference in any practical way.
The shims are not required on the ST1300 as the bulbs do seat properly even after the two lower tabs have been removed from the equation.
Thanks, that distinction is good to know.
The bulbs won’t fall into the headlight housing of the ST1300 with the lower tabs snipped off. There’s a circumferential seat that the flange of the bulb rests on. The tap slots extend outside of that diameter.
Interested to know how they work for you.
Having the fan on the back side may provide better cooling than if inside the enclosed Headlight Assembly.
I'm not putting much stock in the fans, especially long term. If they work great, then awesome... But I don't see them lasting as long as the bulbs.
All the expensive units don't use active cooling so I'm not convinced it's actually necessary...
I'll definitely post up if they die early. No news is good news if they work decently well.
For what it's worth, I put Silverstar Ultra in my 04 in July of 2019 and happy I did. A huge upgrade over stock and easy to install. I commuted at night for many years and struggled with motorcycle specific bulbs. Found these and VIOLA! Good luck chasing the "right ones"!
My experience so far has been that some electronic component that controls the LED fails long before the fans or the LED fails.
As for LED bulb advertising claims. They all advertise that the LED lasts for life, or for 50,000 hrs., or some other extraordinarily long time. That may well be true insofar as the LED itself may last that long but a component in the circuitry that controls the LED always seems to fail long before that resulting in an inoperative light just the same. Deceiving claims as it doesn't matter whether it was the actual LED that failed or not, the result is the same.
Even good LEDs have lifespans closer to 10-20k hours... I'm sure it's exaggerated about as much as the lumens claim.
........ but a component in the circuitry that controls the LED always seems to fail long before that .......
Overheating is the leading cause of failure of the LED electronics (and others, like our infamous ECU....) but efficient cooling costs more to manufacture.......
