Winshield Motor Assembly: Where does this part go?
Houston, Tx
2012 ST1300
I took the windshield adjuster apart a while back to replace the gear, but moved in the meantime and now not sure where all the parts belong anymore!
Anybody knows where this white plastic part fits in?
Thank you,
They obviously fit in Supra Sabre's parts bins.
And it only fits in one place in the shield assembly if that helps.
Perhaps Bob will send you a picture of where it goes, I'm in the middle of a job at the moment and can't find any of my pictures.
Great. Just found it.
Was looking at the assembly section of the doc, where it only says "insert plastic part", but this "M shaped" cable separator is well shown in the disassembly section. Thanks!
While chasing down the dog shims, found this small black plastic/rubber doohickey in my bags of windshield goodies.
Does it belong anywhere in the windshield adjuster assembly?
Thanks.
Yes, it does!
Check out page 9 of the attached document. You should have two, which tells me you have the other one in the right place... or lost it! :rolleyes:
  • ST1300 Window Adjustment Mechanism Clean Lubricate Re-assemble.pdf
...... You should have two, which tells me you have the other one in the right place... or lost it........
Unfortunately, the other one is not in place....the windshield parts got a big shuffle when I moved, so this is quite the puzzle. No luck finding the other one so far......but in the process, I did locate the bolts for the motor mount that I thought were lost!
Thanks for the help.
Private message sent.
