AZ 2005 build - Are you ready for another one?
Well after driving to Illinois (Almost 1,500 miles - took three days to get there) for a family emergency, (Left on the 14th) I stayed, until the 25th, leaving Chris there to help out my son and his family, until he fully recovers, I drove back in two days. I did 830+ miles on the first day and the rest on the second day. One issue we had on our way there was getting over the 10,500 ft & 11,200 ft passes just west of Denver. They were caked in ice, while it was snowing. I put my Tacoma into 4x4 mode and we drove right through it all. A number of big rigs and non 4x4 vehicles we stuck on the side of the road. But we were glad to get through it without any issues.
Now that that's out of the way, back to the bike!
Today, I played musical chairs with the 2004 & the 2012. I sent the 2004 out to the tractor shed, and moved the 2012 by the shelves. That gave me the room I need to be able to work on the bike without having to move my truck out of the garage and the 2012 to where I park the Tacoma.
With that taken care of, I finally got back to the bike. My task today was to reinstall the rear tire and prep it for a sponge bath. That may not happen tomorrow, depending when the rain will hit. I also need to park the engine back up on the lift, so I can get to it. I'll then park the frame where I was parking the 2012.
Got all of that? :rofl1:
Here's the AZ2005 ready for the bath:
Where the bins are sitting to the right of the picture, is where the frame will sit while I work on the engine.
I moved the frame to the side and used the tractor to move the engine on to the lift!
Due to weather, I didn't give the frame a bath, I'll wait for warmer weather. But now I can start on the engine!
That's a good day, the water pump install is a bit challenging and very satisfying when done.
Don't pinch the seal, ha!
With a press, it makes it a lot easier, but coming up with the different things to get everything pressed in, took some time to come up with.
At one time, when I did two in a month, the second one was easy. But that was 5 years ago. :unsure:
Today's progress went a little slow.
I was able to install the Alternator & Starter.
I then pulled the clutch on the 06 Cop engine. Actually it's about what I figured. Burnt to a crisp!
So I looked at the original AZ05 clutch and it was worn, not unusable, but the other clutch I have is in much better shape.
But I need to pick up the 30mm twelve point socket to break loose the basket nut and get a new basket nut to replace it. I'll try the local Honda Dealer and see what they have or have to order. As for the socket, I'm not sure....
Okay, more progress!
Thanks to Larry ( @Igofar ), finding out what size the clutch basket nut is, I was able to pick one up, on my trip (12 point - 30mm). I tried to loosen the one on the 05 engine, but since I didn't have it secured properly, it wouldn't come loose. Today, I was able to break loose the 06 nut, which is the one I really needed loose anyway. The outer basket isn't all burnt up like the inter basket is, so I might use it, if I can't get that 05 loose.
Also, I replaced the clutch slave and other seals and o-rings on the rear cover.
When I removed the 06 clutch slave, I was expecting a real mess, like most of them. Obviously, some one "recently" had replaced it. If I ever need another one, I'll just get the rebuild kit, to make sure the seal didn't go bad, since I was always loosing the clutch, when I tried to start it.
So, next week I'll see about getting the clutch, water pump and cover, all back together.
Are you talking about the oil starved AZ 06?
Not sure who could’ve replaced that clutch slave cylinder recently……
Hey Larry, The AZ 06 is the ex cop bike. The AZ 05 is the bike I picked up through you.
The ex cop bike's engine, is the one replacing the 05's, ran out of oil engine. ;)
So, yes, I'm amazed that someone had replaced the ex cop bike's clutch slave.
When I was removing the Knock sensor connectors, the one on the right side of the engine was melted. So I replaced the wire harness to the knock sensors, and while I was installing the new harness, I decided that swapping the sensors with the 05 sensors would be a good thing. So here is the sensor (on the right) of the 06 and the one on the left is from the 05.
The right side of the 06, looked pretty much like the sensors from the 05. That right side on the 06, must have gotten pretty hot!
Tomorrow, I'll continue with the wiring and then start of the coolant lines & thermostat.
Interesting thread for someone with mechanic experience and a passion for motorcycles, both for rides, repairs, restoration. Good luck with the project
Thank you!
And thanks for the promotion! ;)
As my Signature says, I'm a Tinkerer, far from what I would call a mechanic. I do manage to keep my bikes on the road, but I'm nowhere near the expertise level of Larry ( @Igofar ) or many of the others on the forum. :geek:
One thing I like about working on my own bikes, is when I screw up, I can't blame anyone else and I can fix it without the whole World, knowing about it! :rofl1:
Okay, spent more time out in the garage Friday. I was able to get 95% of the coolant lines installed, along with installing the lower insulator clamps. It sure is easier to tighten those insulator screws without the frame in the way! ;)
On Saturday, I took the frame out (although very windy) and gave it a good bath. I'm hoping to see if I can get the engine in this week.
I did it! :run1:
I was able (with a LOT of TROUBLE) to get the AZ06 Engine into the AZ05 Frame! :hat3:
I decided to leave the front wheel on, but I did remove the rear wheel. While trying to get the engine to align up to the frame, I had to remove the starter and I was not able to get the driveshaft in, so I'll have to remove the swing arm it get that installed. I'll reinstall the starter, after the driveshaft is in.
Also, the electrical connector for the injectors was on the wrong side of the engine, so I had to thread it over to the proper side. and there were a couple other connectors that I had to move, but so far, so good.
It took a lot of time to get the mount holes all to line up.
But I did it! :hat3:
I don't suggest it for the faint of heart! o_O
Okay, more progress today!
My first task was to remove a clamp, and the smaller hose to the front cover. And move the larger hose back behind the frame. It took a little bit, but I got it and replaced the smaller hose, along with adding the three braces in front of the thermostat.
I then removed the swingarm and started connecting up the clutch slave hoses, installed the shifter linkage, ran down all the electrical connections at the left rear and right rear of the engine.
I also found out, that you CANNOT install the starter once the engine is in the frame, and that means you can't swap it out, if you ever plan on replacing your starter. UNLESS, you remove the back cover of the starter, put the gear, in the starter hole, then replace the rear cover to the starter. Then set it in and tighten everything up. I even grabbed a battery and hooked up the negative side, and touched the positive side and I could hear it turning over the engine, so I installed the starter in properly. Dodged that Bullitt! :rolleyes-2x:
I then installed the driveshaft/swingarm. What a PIA. Of course, once you get the driveshaft all attached, then you have to make sure you line up the swingarm pivots for each side. That was fun also, then once I did that I had to attach the final drive.
I'm done for the day! :sleep-2x:
