Problems going from Neutral to 1st or 2nd gear
Spain-Italy
Honda ST1300
Hello
I'm Juanda. First post around here. I recently bought a Honda ST1300 (2005). It's a pleasure to ride on the highway. I don't get to ride it often but the few times I do have been nice. Especially on the highway (except for the freaking tolls).
As I drive it more often, I find more things about it I don't understand. To be precise:
  • Windshield issues
  • Squeaky noise related to the wheel rotation
  • Problems going from Neutral to 1st or 2nd gear
For the first issue, I found a few related posts which I will research in due time.
For the second issue, I didn't find anything so I'll create a separate post soon enough.
And the third issue is what I'd like to be the focus of this post.
It's my first bike with a hydraulic clutch so maybe this is a normal thing and I'm just not familiar with it. Once the bike is running, it changes gears smoothly. However, when starting from a stop, sometimes the gears don't engage. Trying to force them doesn't help. Eventually, I realized the way to do it was to release the clutch lever and try a second time. On the second time, it does perfectly fine. It's not a big issue but it's annoying having to press the clutch twice to achieve normal operation and I doubt this is the intended use. Besides, I now live in Italy and drivers here can get very impatient on the road so I'm a little anxious about engaging neutral on red lights in case I have issues later or it takes me too long to get back in movement.
By the way, the bike engages the neutral gear without issues. It's just coming out of it that's troublesome.
To emphasize again, the sequence usually goes as follows.
  1. I'm stopped in neutral.
  2. Press the clutch lever all the way in.
  3. Push for 1st (or 2nd) gear.
  4. The gear doesn't engage and the bike stays in neutral no matter how hard you push it.
  5. Release the clutch lever.
  6. Press the clutch lever all the way in again.
  7. Push for 1st (or 2nd) gear.
  8. The gear engages fine and I can restart movement.
Do you know what could be going on with the clutch? The bike used to be owned by a mechanic and it seems to be in good condition. Or at least, he was able to hide the grainy bits very well which an experienced mechanic would know how to do for sure. The bike is pretty old but feels solid and they are known to last a lifetime if they're cared for. Let's see if I can help it last.
Thanks in advance
I would start by bleeding the clutch, cheap, easy and simple.
If that doesn't improve things then I would probably start with a slave cylinder strip and rebuild.
If that doesn't work the same for the master cylinder.
Upt.
Welcome from Northumberland, England.
Most of the brake and clutch problems on this bike can be traced to not flushing and changing the brake (and clutch) fluid regularly. Honda says every two years. The guys here with fewest problems do it every year. Your bike is 20 years old, ample time for bad brake fluid to have gummed up the clutch slave cylinder. If you start by bleeding the clutch, read up on the procedure to bleed the brakes and buy enough brake fluid to do both. Consider bleeding the brakes at the same time if you have not bled them in the last year. You must follow the procedure step by step.
The windshield was originally lubed with a grease that some have found to dry out with age. You probably will have to remove the front cowl to dig into the mechanism and clean and lubricate it. The guy at bike quip sells some parts to repair it and this is far cheaper than replacing the whole thing.
Wheel squeak? I'll assume it is not wheel bearings because brake issues are more common. Improper installation of the clips on the pads can cause this...and there are a number of articles dealing with brakes (blue band atop this page, Articles > 1300.....)
Check the hole in the brass bush in the clutch lever is not worn
Bleed the clutch fluid of all air
Lubricate the gear lever linkage
Then move on to the more expensive solutions
edit. Clutch bleed. Use the technique of pumping the lever a few times, then hold the lever in, then open the bleed valve. Close the bleed valve just before the fluid stops flowing. Repeat. It is the only way to get the fluid changed in the slave cylinder.
edit 2. The clutch lever brass bush - the pushrod goes INSIDE the hole. Mark its position with a felt pen on the top of the bush before re-assembly. @Gus1300 below reminded me about that in his comment below.
And pay attention to how the push rod goes into the brass bushing/clutch master cylinder piston when putting the lever back on after checking the bushing...don't ask how I know!
edit: to expand on John's comment above, it not only goes into the brass bushing, but it goes in with the squared off end into the brass bushing, not the round end. That end goes into the piston cup.
Thank you all for the very useful replies. I'll try to troubleshoot it from simple to complex as you suggested.
I'm sorting out an issue with the garage and as soon as I can I'll start working on the machine.
If the first clutch pull does little, but the second pull works, I would suspect the master cylinder is worn.
Definitely lube the shift linkage, likely never been done and won't let the shifter parts return to proper position....
Of course check the clutch system as others have also noted.
I don't think that I knew that, though it makes sense to put the round end in the cup. I've only ever had need to separate the push rod from the rubber boot once. I noted that the two 'halves' were different so I probably put it together correctly.
That was my first 1100, 1996 model. 29,000 miles on the clock when I got it and clutch was a bit iffy. I tackled the master and slave cylinder and cleaned off the coating of thick black paste that I found, and then wondered where the seals were.
I took my brother's calipers apart a couple of weeks ago - brake issues. ST1100 1997 model. The pistons were pitted, but mostly the seals were pretty sound - apart from the ones that had melted in their grooves due to brake drag heat. But 28 years with little servicing. Not one of the seals had turned to a thick paste. I often wondered what the previous owner had put in my clutch fluid to result in them turning into the consistency of very cold butter.
Someone I once helped change a brake master cylinder piston. I explained about ensuring that the seal went in flared end first, and showed him how to do that and to use a little brake fluid to help. He commented that he found it easier to lubricate the seal with washing up liquid. I often wondered if that was how my clutch seals disintegrated.
But I digress.
Hello
The weather is getting nicer, so I finally got around to doing some maintenance on the bike.
  • Clutch fluid.
  • Brake fluid.
  • Radiator fluid.
  • Oil and oil filter.
  • Air filter.
  • Rear suspension preload fluid. (The thing that apparently is not in the manual)
  • Fuse change that affected the windshield motor. (There is another thread about that)
The old fluids didn't come out very nicely, to say the least.
The overall riding experience is noticeably better, and I thought all the issues would be resolved, but I'm still experiencing the same troubles, although maybe to a lesser extent.
  • The squeaky noise related to rotations is still there. I think it went down slightly, but it's still there. I still haven't been able to locate the source. Maybe a local deformation in a brake disc like an m-shape? I mention the m-shape because I think I noticed it even happening two times close to each other before completing a rotation, and it repeats with every full rotation of the wheel.
  • 1st gear is still having some issues engaging. I sometimes need to pump the clutch lever twice to get it to engage correctly. The exact pumping sequence is described in the first post of this thread.
  • After putting everything together, I went on a little test ride to check if everything was fine. After warming up the engine, I engaged 1st gear, released the clutch, and got it going at full throttle. Everything was going well (what a bike!), but near the high end of the regime, I had an abrupt loss of power, and then it came back. It let me jarred so I didn't test much farther. Besides, I wasn't in the best location to be doing such tests, and the weather was getting worse.
    I don't know if the clutch disengaged the gear for a moment, or if the motor skipped a power cycle, or what other possibilities could be there. I consider myself a chill rider, so I guess that's why I never experienced this before. I likely won't have issues with it since I don't rev the bike as high anyway, but it still concerns me.
    Maybe the bike cut the injection to protect itself? For real, I never rev bikes to the limit, and my previous "sporty" bike was carbureted and just mechanical, so I'm just realizing that maybe in this case it was the electronic power map of the bike coming into action. I hope that's the case.
I have a bittersweet feeling right now. I was feeling great about finally being done with the maintenance, just to realize the issues are still there... Besides, working on the bike takes forever. I'm even considering leaving it as it is if it's not dangerous.
Can you share pictures of these things? Maybe I'll need to check that next.
Thanks in advance
Again, if a second pull disengages the clutch more fully, then the issue must be related to the fluid, and not a mechanical, physical part. The question is what does pulling twice do that's different from once?
Either some fluid is disappearing between clutch uses, or the master-cylinder cup is worn, and the second pull puts fluid into the line faster than it can be pushed back into the reservoir by the clutch springs.
There is a limiter to prevent the engine from over-reving and damaging itself. You probably increased the RPM to where the limiter kicked in. I think I read on here that it kicks in somewhere around 9,000 RPM but I'm not sure about the actual RPM.
Max torque is at 6,500 rpm, specs list rev limiter at 9250. Foolish reving it that high. Your out of the power band over 6,500.
Hello
  • Windshield issues
Thanks in advance
My rt does that some times and my st also did that. The trans does not have syncro's like cars, the gears don't mesh so just slightly release the clutch, get the gears turning and it will go into gear.
Regarding the fluid disappearing, I can't see any leaks. Is it possible it's leaking into the motor or something like that? Kind of like when radiator liquid turns dark because some oil is getting into it, or vice versa.
That's a relief to hear. It was just a test. I'm not planning to rev it that high normally (not even close most likely).
I couldn't get a reading of the gauge because I felt as if I took my eyes off the road, I'd run out of space and crash. I wanted to make sure the bike was fine, but I don't think I'm doing it again anytime soon.
Anyway, I'm just glad that was normal behavior.
My rt does that some times and my st also did that. The trans does not have syncro's like cars, the gears don't mesh so just slightly release the clutch, it get the gears turning and it will go into gear.
Hmmm. Do I just live with it then? Again, I feel it got better after the change of clutch fluid, but I'd have loved it to work perfectly whenever I try to use it.
Some of my previous bikes would produce a loud CHUNK noise when engaging the first gear, but it'd always engage nonetheless.
Definitely, leaving it as is would make my life simpler. The only remaining concern would be the squeaky noise related to wheel rotation, which I haven't been able to diagnose yet. I don't even know if squeeky is the right word... Probably not. I'm not a native English. It's more like a deep rubbing noise.
When you said the old fluids did not come out nicely, do you mean the old soup that came out was dark and dirty? For a 20 year old bike, if the fluids have not been changed frequently, you might have clutch slave cylinder problems.
I remember someone posting pictures of the clutch bushing in another thread. You should be able to find that with a search.
Yep. Although I don't know how bad is too bad. For now, I'm just hoping it's as Al st1100 was describing so I can forget about the clutch.
Regarding the "squeaky" noise, I'll try to take a closer look over the weekend. Maybe I'll finally find out what's causing it.
