Quite a bit of real estate between these two statements. Is this a case of two different FOBO models?
I have no idea why there's a difference in our experiences. I've never had to move roll or ride the bike to get a reading of the tire pressure. It's the main reason I chose FOBO. If I had to bump or roll the bike in anyway it would be a deal breaker.
Sadly none of the many reviews I've read or watched nor the instruction manual tell you how to check the PSI. They show it displayed but not how to get there. Seriously? But...
...shows the caps being removed and replaced so I infer this matches my experience of the bike not being moved to check pressures. From my personal extensive experience with this system and the lack of any reviewer or manual mention of having to bump or roll the bike my statement stands.
This video does mention checking pressures without having to ride the bike first. I infer that means not moving the bike with the FOBO 2 system. In either video it's possible that moving the caps as part of the installation is the equivalent of moving the bike. But if you had to do that to any degree to get a reading I'd think the instruction manual would make a point of doing that.
It's really disappointing that the specific operation of the kit is ignored by almost everybody.
As long as I'm in BT range I can open the app and see the last known tire pressure. Then I refresh and the current pressures are show. This is without touching or moving the bike. I haven't checked the firmware but have the latest version of the iOS app.
One problem I've seen with two F2 kits is the included batteries have very short life spans. The app shows battery life and none of four batteries were > 50% out of the box. Replacement with Everyready batteries gave me a little over a year of use.
Maybe a firmware update has changed the operation. As a BT device I'm sure the caps are "always On" waiting to respond to an inquiry.
