I'm considering switching from Rotella 15W-40 to 5W-40. Would this be a wise choice? Any input or recommendations would be appreciated.
This is an easy one. Desire to use a cheaper oil. Some folks pick up the idea another viscosity/brand is better. Some folks think they know better than the mfr, for whatever reason. Some folks listen to a perceived eggspert on youtube. Take your pick.Insofar as the viscosity rating goes, I never understood why anyone would stray from one of the viscosity ratings that the vehicle manufacturer has specified for a given vehicle.
This is the BEST written response in an oil thread I have read period!Debates will rage forever about which type/brand of oil is better. Regardless of how logical opinions may be or how compelling the available evidence is these debates will continue to rage. Because of that I am expressing no opinion on oil type/brand however, the question here is in regards to the viscosity rating not the type of oil.
Insofar as the viscosity rating goes, I never understood why anyone would stray from one of the viscosity ratings that the vehicle manufacturer has specified for a given vehicle. There are many factors that go in to deciding what the best oil viscosity is for a given engine, and many of those factors are variables that change as the engine and the oil temperatures change. In many cases the engine manufacturers don't even decide themselves what the best viscosity oil is for their engine. They send the engine design specifications to lubrication engineers who do nothing but specialize in lubrication chemistry and mediums. These engineers analyze the various design specifications and tolerances of the engine and they tell the engine manufacturer what type and viscosity of oil is best suited for that particular engine under various temperature ranges.
I acknowledge that both of the ST engine designs are pretty old now and were not as highly engineered as modern engines are. I also realize that most motorcycles will not see temperatures as cold as automobiles routinely do so the variances listed above likely have a lesser influence. Having less sophisticated engineering these engines are probably more tolerant of straying from the manufacturers viscosity recommendation than newer engines are. It is also obvious that when they were developed choosing the best oil viscosity was not made with the same level of sophistication as it is now. Regardless of all that the question remains- Why stray from the manufacturers specified viscosity? I am under no illusion that I know something that the engine designers and lubrication engineers don't. I doubt that I have the capacity to competently decide if a viscosity that they do not recommend is not only not harmful to the engine but is actually a good choice. Further complicating the matter is the effect that this choice has on the transmission and clutch as they depend on the same oil but for very different requirements.
People can and will continue to use whatever type and brand of oil that they think is the best. Just about any oil on the market is available in several different viscosity ratings. Amongst those available choices it is unlikely that there isn't one that is specified by the manufacturer. Regardless of the type and brand of oil chosen, the logic of using a viscosity rating that is not specified by the manufacturer escapes me.
5w 40 has less film strength than 15w40. Both oils will flow the same above 20 degrees f. Now if you were riding all winter 5/40 would be better but if your intention is find a better lubricating film the 5/40 is not the way to go.Measuring how much oil is expelled from the engine after a dyno run misses the real purpose of lubrication. It’s certainly not part of any lab-standard test. The real focus should be on how quickly oil pressure reaches the top of the engine during a cold start, when lubrication is most critical.
Beyond that, oil plays a key role in engine cooling and in carrying away impurities, which is why using the correct viscosity is essential.
Ultimately, what truly matters is the resilience of the lubrication film and the stability of oil flow under all operating conditions. That has little to do with what ends up in the catch pan after a full-throttle run.
Like everything else in the automotive world, engine oil is constantly evolving.
Maybe it's worth considering that progress has been made, and there could be better options today.
Post one.The 5w40 versions always break down in grade faster than the 15w40 versions in the UOA’s I’ve had come back.
Anecdotal evidence of one example is not statistically significant.A member here W0QNX has over 400K miles on his ST1300 using Rotella T6 5w40 and 15w40.
And that's something also to consider. I had over 100,000 miles on my BMW F800GT when I traded it in. I have no idea what the upper end looked like. But I do know that it ran smoother than it did when new and used no oil between oil changes.The lack of oil related failures in general and specifically in this forum speak for themselves. Modern engines are very forgiving.
Not even remotely interested in discussing/explaining or defending my thoughts or opinions about anything motorcycle related with you.Post one.
I think we could come up with two other kinds of people. Everyone with the same opinion as mine, and everyone else who is wrong.The two types of people who defend stuff are those who sell it, and those who buy it.
