Question about Rotella 5W40
The 5w40 versions always break down in grade faster than the 15w40 versions in the UOA’s I’ve had come back.
Not relevant for full synthetic oil as I learned tonight, thank you for mentioning it :thumbsup:
In UOA, the Rotella T6 5W-40 match the T6 15W-40 for grade retention (Shell labs).
The HTHS (High Temperature High Shear) looks to be the Key, both 5W-40 and 15W-40 meet or exceed the same HTHS spec (Shell labs & oildepot.ca)
So says the people who sell and market it :rofl1:
Shell also claims their stuff is JASO certified.
If you want to use it, use it. Your bike, your choice.
If you don't like it, try something else.
I think we could come up with two other kinds of people. Everyone with the same opinion as mine, and everyone else who is wrong. :)
Maybe we could get the emotion level down some?
No emotion from this camp, as I don't care what oil folks use.
I just threw out some information based from my experience.
We could probably add two more kinds of folks to that group. Those who've torn down and inspected many engines, and those who just repeat what they read on forums.
I'm out of this thread.
I know, facts don’t always sit comfortably.
Insofar as the viscosity rating goes, I never understood why anyone would stray from one of the viscosity ratings that the vehicle manufacturer has specified for a given vehicle.
Probably because there's been numerous cases of manufacturers changing oil ratings due to engine issues, largely because they wanted to meet CAFE standards and were using oil that was too thin in order to get under said standards.
The OEMs aren't interested in engines lasting as long as possible, they're interested in meeting the MPG standards set forth by the countries they're selling in, and the engines lasting at least through the warranty period. That's it. This idea that these engineers making these decisions are doing so based on anything outside of the powertrain warranty and emissions/mileage standards is absurd and wishful at best.
Your argument about auto manufacturers using lighter oils for MPG reasons rather than engine longevity contradicts the idea of using something like 5w-40 Rotella, as the 5w part of the rating falls under the manufacturers minimum recommended viscosity range.
So far, motorcycle manufacturers aren’t under the same CAFE fuel mileage pressures as autos. This leads me to believe there’s less distraction of priorities for motorcycle oil from engine protection in this industry.
Your argument about auto manufacturers using lighter oils for MPG reasons rather than engine longevity contraindications the idea of using something like 5w-40 Rotella.
So far, motorcycle manufacturers aren’t under the same CAFE fuel mileage pressures as autos. This leads me to believe there’s less distraction of priorities for motor oil from engine protection in this industry.
My point is purely that just because an engineer that works at the OEM said it, doesn't mean it's actually true. Engineers make mistakes, and companies have different priorities than end users.
Motorcycles most certainly have to meet emissions standards.
The CAFE requirement I referenced is a fuel mileage requirement, not emissions. I did not reference emissions standards. Being an engineer by profession, and understanding some of the standards and validations a manufacturer has to comply with leads me to perhaps a higher level of respect for those engineer’s decisions than those outside the profession perhaps.
I'm considering switching from Rotella 15W-40 to 5W-40. Would this be a wise choice? Any input or recommendations would be appreciated.
The only question I would ask is why are you considering the switch? Some ask why not run the recommended 10-40 and I understand that T6 only comes in 5 or 15 weight and many people want to run Rotella as it is a proven, low-cost and safe performer. So I would think most people are unsure whether to go thinner or thicker than the 10 weight recommendation. If that is your only reason for the question, than I would say 15 weight. The 5 weight should only be an option if it were really cold. As @Al st1100 pointed out, GM is in a big pickle from running to thin an oil in some of their engines... :twocents1:
I am certain that fuel efficiency is a consideration in the choice but to claim that it comes at a significant expense to longevity I find highly questionable. Modern automobile engines are more mechanically reliable and longer lasting than they have ever been and that is with these oils. Yes there are exceptions to that and there will always be examples of premature engine failures for many different reasons including because of a screw-up in the choice of oil. The exceptions don't define the average however. I don't know specifically about motorcycle engines but I can't see it being hugely different in this regard from automobile engines.
Like everything else in the automotive world, engine oil is constantly evolving.
Maybe it's worth considering that progress has been made, and there could be better options today.
I don't think that there can be any rational claim that engine oils have not improved. Any modern 5W oil is of a much higher quality than any 10W oil that was available when the ST1300 was designed. By the same token the same is true of any modern 10W oil as well. The quality of the oil is no longer the determining factor. Your statement assumes that a modern 5W oil is far superior to the lesser quality 10W oils that were available when the ST1300 was designed and it therefore must be an improvement. I have no idea because I am clueless as to whether the trade-off in viscosity is worthy of consideration or not. This is a question that I do not feel needs answering. The 10W and 15W oils available today are of the same high quality as the 5W oils. Since there are high quality oils available that do comply with the viscosity ratings that the manufacturer has specified I just follow the recommendation.
