I plan on following the path of the existing cable(s) and the lock to lock requirement will certainly be met. The entire cable could possibly be shortened depending on where the connector(s) I'll be attaching to is located. I haven't had to tear the bike apart yet so I'm not sure of the location of those connectors. If they are under the tank, the entire harness from the switch could be shortened and I'm just trying to get an idea by how much. I've got nine-pin connectors and a few others that I'll use to modularize the whole assembly. I could use single-wire spade connectors or bullet connectors, but I like neatness and organization in my projects.That's on my list, complete with the requisite GoldWing pod.
Meaning, I have not done this yet.
However, it would seem that you want enough cable to allow lock-to-lock handlebar movement, but not much more than that.
I've read this entire thread shortly after joining, so I will have much to revisit.
Which specific cable are you referring to in the GW switch?
I foresee following the path of the existing cables coming from the right grip, just bundling them together as best you can.
