Checking the specs from Racetech they noted that 8mm preload was applied to the new spring.
Now you are talking, does that make sense now? 11 makes sense as your spring is quite a bit stiffer than stock but not so stiff as to create excessive free sag.After several months of dealing with this it just came to me that the RaceTech numbers are 30mm rider sag. When set there I get 11mm of free sag. This puts me much closer to the recommended free sag number. RaceTech and Sonic both suggested that 36mm of sag front and rear was the sweet spot for the ST1300.
Any advice would be appreciated.
can't help you with the spring questions, but you should start a new thread with a title that describes your specific questions to get better response.
The collar goes on the top end by the pre-load adjuster.Hi guys!
I'm an inactive user for some time now but, have finally gotten around to installing a 23.2kg/mm Race Tech rear shock spring and am wondering about the inch shorter RT spring and which end of the shock I should put the new collar on?
Any advice would be appreciated. Thanks
I am 275 pounds, and my girlfriend is about 135. We mostly ride two-up, with the bags and trunk loaded. Spring suggestions, anyone? What does RT charge for the spring swap?
The bigger issue is the stock shock isn't valved correctly for a stiffer spring, and that it may cause other issues. Humm.......
Of course they tell you that... they are trying to make money.
Seriously, I'm fine on my stock shock and increased spring. Could a re-valve and re-build help, probably. Will it cause problems?? Don't really think so.
I just looked at them also. They are recommending 23.2kg ( Is this the 1300? ) But that is just with my weight alone (260) Their calculator asks for rider weight only without baggage. When i ride 2 up we are 440# She does not like to go on long trips, so gear weight is next to nothing if she is on. At 440# though I wonder if thats really enough spring and if I went heavier...would it be too stiff when Im alone. Ugh..I have a head acheThat's kind of what I'm thinking too. My days of doing trackdays are long gone. This is just a sports touring bike, one that's terribly undersprung with me and the GF on it. All the suspension companies tell you that the valving adjustments on the OEM parts don't do much anyway, so perhaps the OEM shocks wouldn't have much "input" from a valving perspective with the replacement of the old spring with a new one. One way to find out, I suppose. The bigger question now becomes what spring rate? I've never heard anywhere on here about anyone doing more than a 1300# or maybe a 1400#. But they (Penske) are suggesting at least a 1400# and maybe a 1600# for my application?
According to Racetech, the stock spring is a 17kg/mm,which would equal about 950#
The stiffest spring they sell is the one they recommend, 25kg/mm, or in other words, about #1400
Penske says (for me) at least a #1400, but for 2-up riding, more like a #1600
700 lb/in = 12.5 kg/mm
650 lb/in = 11.6 kg/mm
600 lb/in = 10.7 kg/mm
550 lb/in = 9.8 kg/mm
500 lb/in = 8.9 kg/mm
450 lb/in = 8 kg/mm
400 lb/in = 7.1 kg/mm
350 lb/in = 6.2 kg/mm
300 lb/in = 5.3 kg/mm
250 lb/in = 4.5 kg/mm
1. 1300 is not even the biggest they offer. they have a 1400 lb spring also.
