The saga continues...
Haven't ridden much (at all) this season, but earlier this week I packed up the bike and headed towards Michigan to work an NCAA Track Championship. Thought this would be a good opportunity to test the bike on a longer ride to see if the fuel pump relay "fix" was actually a fix. Doesn't appear to be....
Nearly full tank when I left Indy...got approx 90 miles north running at interstate speeds and all of a sudden the engine begins to loose power and run roughly as though it was starving for fuel. Pulled off at an exit, left it running for a few minutes and it eventually smoothed out with a bit of revving. Hopped back on the interstate and had no problems finishing off the next 50 miles to my overnight location in NW Indiana.
Next morning the bike fired up just fine and I ran another 100 miles or so before stopping to fill the tank. Engine was shut off during the refuel. Fired back up just fine and I continued another 80 miles or so where I stop for breakfast. Engine off for about 20 minutes.
Starts just fine, but after I'm back on the road for 2 miles the engine begins running with a loss of power and eventually dies. Pull off to the side of the road, wait 5 minutes, attempt to restart and it fires back up running smoothly. Start rolling again and within 1.5-2 miles it dies again. Repeated this same process of waiting a few, restarting normally, engine dying in 2 miles about 6 more times as I limped back to the nearest town. Did not hear fuel pump "priming" noise when I restarted any of these times.
Pulled into the parking lot of a NAPA store to contemplate my options and bike was off for about 25 minutes as I made a few calls to arrange pickup in case I couldn't make it any further. Did triple check the fuel pump electrical connections on top of the tank and they were solid.
Started bike back up again without issue, drove it 1/2 mile to gas station to top off the tank (had only covered about 100 miles since last fill up). Fired it back up again after getting fuel and it ran normally for 45 miles where I stopped for a meeting and the bike sat for a couple hours. Started back up normally and I ran it another 10 miles where I stopped, engine off and topped off the tank again. Ran fine for 2 miles and started to run roughly, but I pulled over, revved the engine a bit and a normal idle came back. Finished off my riding for the day with 1 more mile to the hotel.
Ambient air temps were not hot at all - always between 50-70F. Was not in stop/go situations...so don't believe heat was an issue.
On those short 2 mile runs it seemed to run only long enough to run the fuel that was in the carbs dry...but if I wasn't hearing the fuel pump prime the system, why did it start back up normally after sitting for 5 minutes? Gravity able to work fuel back into the carbs?
Thoughts on this recent set of circumstances?
Fingers crossed that my voyage back to Indy on Sunday goes smoothly.
. Will probably replicate what I did last July on my trip from Indy to Atlanta when I faced the same issue - I had success just NOT turning the engine off the entire trip back - even during refueling stops. But when I get home I'd like to dig back into things to keep looking for the solution to the issue.
