My contribution. I installed mine on my 2008 ST1300A last winter using the Rostra cruise and Centrodyne signal divider.
I tried using a new Goldwing right side control switch assembly but discovered it hangs down further and will hit the gas tank unless the bike has a bar riser fitted. (I have a new Goldwing switch for sale, pm me if interested)
But I like an integrated look, so I decided to mount two cruise control switches in the blank stock switch area of the right handlebar.
Switch on left is: cruise power On/Off. Switch on right is momentary down for Set and Coast, up for Accelerate and Resume. Digi-Key is a great source for the switches that fit here.
Next to tackle was the best way to configure the throttle connection. Throughout the forums, nearly every rider complained of having difficulty getting smooth operation, without surge, lurching or hunting etc. because of the high HP/weight ratio of their bike as compared to that of a car for which this control was built.
I went for the low connection point of the black cable to minimize obstruction with the air intake and to configure the longest arm on the throttle shaft to minimize the sensitivity at which the cruise would operate the throttle. I fabricated a steel arm instead of aluminum so I could keep the arm thin and maximize the # of threads the throttle shaft nut would have to secure the arm. After lots of trial and error, I arrived at the same max length of the throttle arm as others had.
I drew power and ground from the quartet 9-pin connector. I also liked the idea of having an indicator light to show when the cruise was ?Engaged?. It?s very simple to splice directly into the neutral light circuit at the same 24 pin connector as the VSS wire, no diodes needed. Mine was pin #2, light green/red wire. This has turned out to be
very useful so you always know when the cruise control is engaged; we have enough surprises while riding already.
Time for the road test. Based on what I read, and now from my own testing, the goal is to find the dip switch and divider settings that will yield: smooth operation, accurate speed control, while minimizing surge, overshoot and hunting. My conclusion is that it will never be as smooth and controlled as a car in all conditions, but you can get pretty close. Since the bike has a very sensitive throttle, rule #1 is use the cruise in 4[SUP]th[/SUP] and 5[SUP]th[/SUP] gears only; any gear lower will exhibit lurching and control problems.
Pulse divider set at: divide by 4
Rostra settings: Extra low, 38600, 8cyl Low, square wave, manual, open circuit
These settings will yield a cruise that will have a minimum ?set? speed of about 40/45 mph and a pretty responsive/accurate Set when activated. Resume works, but best if you have the bike at a speed very close to the set speed when you hit the resume button.
(I found that 6cyl low and 4cyl low also work pretty well with the rest of the settings the same. The ratio between your final pulse-rate from the divider to the VSS setting will determine the min set speed and play a role in control stability. A lower VSS setting will yield a lower min set point, but more erratic control. )
Divide by Two Linkage,
I never got the ?smooth like a car? operation that I was hoping for; still too much throttle sensitivity under certain circumstances. I re-read a previous discussion about a divide-by-two linkage for his throttle control and how the writer was much happier with the results but he never posted any photos. Another writer discovered his cruise never pulled the throttle open more that half way under any riding circumstances.
It was still cold here in Chicago, so I had the time to work on this some more and came up with my own divide-by linkage to help further desensitize the throttle response. Knowing the above, I created this throttle linkage layout.
A one-inch pull on the cruise cable results in a much smaller pull on the throttle shaft and the cruise can only open the throttle about half way. (although the rider can always manually operate the throttle to WOT whenever desired) One other benefit of this configuration is less opportunity for interference between the air intake/breather hose and 1/ the throttle arm and 2/ the cruise actuator cable. (pictures show I left my throttle arm full length, just in case the linkage plan didn?t work. Some day I may cut off the unused length)
I also wanted to operate the cruise at lower speeds, so the final best-for-me settings are:
Extra low, 8cyl low, 24000, divide by 4.
This lower sensitivity linkage and associated settings give a bit smoother operation and a min set speed of about 33mph. ?Resume?, ?Coast? and ?Accelerate? operate somewhat predictably but only when activated close to the current ?set? speed.
In hindsight, I would have omitted the unnecessary on/of switch leaving the cruise power always ?on?. And I would have installed only a pushbutton switch for Set and Coast, and forgone the Resume/Accelerate functions.
Caveats, disclaimers and warnings: This linkage is much more complicated than the standard configuration and if not properly implemented could end up in non-failsafe or potentially unsafe operation. I?m sure some of the mechanically inclined can come up with a better implementation of the divide by linkage idea and if they do, I?d love to see their work.
Other notes:
The Centrodyne divider I received requires the gain setting to be jumpered to ?on?. For some reason if no gain is set(no jumper), above 50mph the output signal drops to zero volts, zero HZ. My gain is jumpered to the 2[SUP]nd[/SUP] lowest position.
Kudos to all in the Forum who have contributed their knowledge and experience. This would have been hugely difficult without them.
