ST1100 engine removal question
Pulling the engine from the '98 I bought and have a question about the transmission/swingarm connection.
The service manual doesn't mention removing the swingarm as a pre-requisite task when removing the engine, and the engine is removed with the transmission intact. Since the driveshaft is connected to the transmission through the swingarm, that connection needs to be uncoupled before removing the engine. So I'm guessing that after removing all the engine mounts you just move the engine a little forward and the driveshaft will just slip out of the transmission housing? Are there any fasteners that need to be removed, or is the rubber coupling boot all that's there?
any advice will be appreciated, TIA
Doug
As Martin said, Nope, yes.
The drive shaft is spring loaded so it will kind of 'jump' back on during installation with a little encouragement.
If you can watch Allen Millyard's videos for engine removal, I found them to be really helpful.
But really pay attention to where he has the ratchet straps attached - it is not obvious at first glance.
Getting it out is a lot easier than putting one in (done both twice). ;)
I also found you can remove the alternator (you can get to all three bolts but be careful the 'plate' doesn't come out with it) and slide it back a little bit.
That makes getting the engine out (without it in place) a lot easier (or it did for me).
The 'hangup' is when you remove the side frame on the left side, the 'attachment' piece at the back left side is sticking right in the way.
You have to rotate the engine almost perpendicular to get it out.
I found an auto tranny jack helped a lot dealing with the weight.
Or another option is just hook the whole frame to a 'skyhook' and lift it off the engine.
Very few wires to disconnect, easier to remove the radiator and get it out of the way.
Don't forget to disconnect the shifter! :doh1:
Good luck as it is a bit of work but definitely doable by yourself.
I'm not sure I'd trust my ceiling with that much weight. :think1:
Besides, no need when I can use the tractor! :rofl1:
Well, my roof rafters are well built trusses and the 'connection' spans a couple of them.
And it would be a lot of trouble to get my tractor into my workshop ... ;)
Thank goodness, when my builder built the garages, she put in tall garage doors! :thumbsup-2x:
But my tractor is old IH Diesel - a big farm tractor (tall wheels, etc.)
I figure if I put in low and hooked to my house, it would probably pull it off the foundation!
It was cheaper to buy a big one at the time than a small one because all the 'city' farmers wanted the small ones. ;)
I also have a full size backhoe but unfortunately it's not running.
I wish I could find someone to haul it off as I don't have the patience to fool with it any more.
No, I bought Al's non-running '98 that he had advertised here a week or so ago.
After pulling the carbs on the '98 it was obvious it never had the coolant hoses replaced, so that would have been another couple hundred bucks in parts in addition to whatever it would take to sort the carbs. I decided that rather than spend the time and money to get his running I'd stick with my known condition '97 and swap as many parts as was practical. So that's how all the red bodywork became available. It didn't make sense to try for two running bikes, my '97 had too many issues to consider selling it, but now its in great shape.
The ST is such a low-demand dinosaur the only m/c salvage yard I could find didn't want it, so I'm dismantling it and I'll ask one more time here in a few days if anybody wants anything else from it, and then its going to be history.
FWIW, the '98 had 67k miles on it.
Hello, I am interested in the engine.
OK, since you're local it might work.
I don't have any way to maneuver a 200+ lb engine around so my current plan is to remove the heads first, and deal with just the block.
I have no immediate use for the engine parts, so if you have a way to come to my house and pick them up, either complete engine, or in pieces, PM me and we'll talk about a plan. If you want a complete engine you will probably have to be willing to help me wrestle it out of the frame. I have cutting tools if we have to remove it violently, we'll get it out one way or another.
Doug - What I did was get a cheap furniture mover cart and rolled the engine up on it.
A ratchet strap or two and the engine has 'wheels'!
Harbor Freight For $13
A lot less hassle than removing the heads and the engine stays in one piece. ;)
Actually UP, I already have two of those HF dollies in the garage. I had already considered that maybe we could lift the engine onto that and roll it up a ramp into a truck or something. But it would have to be a pretty smooth ramp. We'll see, I'm not doing any weightlifting at my age, even though I'm in fairly decent shape.
It looks like there's not a lot of clearance to get the complete engine out the left side, the alternator and transmission seem to be a pretty tight fit through that cutout in the frame. Your earlier comment about having to rotate it perpendicular didn't sound encouraging, I'm working with a simple floor jack that probably won't rotate easily with that much weight on it.
Doug - Yeah, the only way to get it out is to rotate the engine down to the left.
If are you not going to keep the frame, you could cut off the frame 'extension' at the left back and probably get it out easier.
I found on my second 'removal' I could remove the 3 bolts holding the alternator, pry it back from the engine and it made things a lot easier.
You can't get it out of the frame but it sort of sits there while the engine comes out.
Allen Millyard's video removing the engine gives you a really good look at the technique.
This is the one you want to watch - about the first 10 minutes or so -
